M: Jaeger-LeCoultre Master Ultra Thin 38mm
untitled
JLC'n ultra ohut klassikko. Ostettu viralliselta jälleenmyyjältä Italiasta 17.05.2017. Täysin uudenveroinen. Full set.
Hinta 3600 € (OVH noin 6500-7000)
Hieman Internetistä kopioitua kuvausta:
The Master Ultra Thin is a classic from JLC, one of the thinnest mechanical watches to be manufactured, now available in a larger case diameter of 38mm. The construction & assembly of this watch is so demanding that the production is carried out in the "Watchmaking Specialties Workshop" of JLC together with Minute Repeaters & Tourbillons.
This watch features:
Polished Stainless Steel case.
Reflective brushed sunray Silvered colored dial with applied Index & Arabic Numeral hour markers.
Dauphine shaped hands.
JLC Caliber 849 is 1.85mm thick, beats at 21,600 vph, contains 19 jewels, composed of 123 parts & has an approximate Power Reserve of 35 hours. As with all JLC watches this watch has undergone a rigorous 1000 (41 days) test before leaving the factory.
Rhodium-plated arabic numbers and hour-markers!
This watch is also known as: q1348420, q134.84.20, 134.84.20
Kuvat ( ):
untitled
Vs: M: Jaeger-LeCoultre Master Ultra Thin 38mm
Nostetaan ja alennetaan hintaa pikkasen, jos on siitä kiinni.
4400 €
untitled
4000.00 € :gift
need money
